A cel recently came on and when I popped in the durametrics it read:
p1276
Porsche fault code 22 - Oxygen sensor ageing Delay bank 2 below limit value
p1126
Porsche fault code 356 - Multiplic. mixture adapt. lower load range B.1:
What do these readings mean? I'm assuming I need to replace an o2 sensor?
P1126 Oxygen Sensing Adaptation, Lower Load Range, Bank 1 - Above Limit or Below Limit
Possible causes:
- Incorrect signal from MAF sensor
- Fuel pressure too high
- Fuel injector fouled
P1276 Signal Delay Time for Oxygen Sensor Aging, Bank 2 – Above/Below Limit
Possible causes:
– Oxygen sensor ahead of TWC
– Leak ahead of TWC or in the area of the oxygen sensor after TWC
– Wiring (oxygen sensors exchanged)
I would fix the P1126 first and then reset the codes and see if any come back.
