Maybe someone can shed some insight into what is up with my sunroof.
It stopped working all of a sudden but if you played with the switch it would work intermittently and the tilt functions worked fine it was just when you toggled button to rear that there was an issue. So I figured oh easy fix the switch is bad, ordered switch and swapped it out. Viola' it worked. Took it for a drive and the more I actually played around with it the more I realized it's not working like it used to.
It was always one touch open/close now I 50% of the time it's one touch close 50% of the time it hold to close. One touch open is a hit an miss BUT, if you tilt it first then close it it will one touch no problem? The motors seem fine speed once it gets going is good, no binding tracks are clean and I lubricated them a little.
WTF? It's like it has lost its mind. Any ideas or where I can start trying to figure out what is happening?
Do a search on teaching, training, or retraining the sunroof. The procedures are here somewhere.
It's something you have to do every once and a while, such as resetting the battery.
It involves holding down the buttons for a while and following a certain procedure.
I did mine but no luck still doing same thing. I have a feeling may be doing it wrong. I tried with car on and car off but ignition ket to on.
Sunroof works but have to tilt first and then close it so it will one touch???
Try doing the full learn and teach procedure with the car running. Follow it step by step exactly, it's always solved this problem for me.
