I have a 2005 Cayenne S with GCC specs.
Recently it started leaking air from the front suspension so I took it to the local Porsche car dealer... they kept the car for 3 days just to try understand where the leak is and, well they made me an estimate that replaces most of that suspension.
I would like to know if there is anywhere I can consult the part numbers for the front right suspension of the car.
the parts they proposed to change are:
Air Spring Right Strut
Air Spring
Supporting Mount (2x)
Seal (2x)
Sealing Ring (2x)
Damper (2x)
and although it is not on the same issue, but I also need the part number for the wishbones (left and right)
thanks for your help.
Luís
Edited by Luis Galvao
