Anyone got any tips on how to remove the panels under the glove box( and the glove box if necessary) and the panel under steering wheel?
Need to do some wiring with my phone kit, think I have to remove some of those panel to thread various wiring through.
Any tips would be appreciated.
Regards,
Anthony
Its sooo easy. Look in between where the panel and the dash meet, in that crevice you'll see a t20 screw. Remove the screw and pull down to dislodge the trim clips. On the drivers side you'll need to remove the OBD2 plug and the light. On the passengers side you'll need to remove the light and possibly some 12v adapter inputs.
