Hello,
So this morning I noticed an odd clunk/knocking sound coming from my '00 986 2.7 engine.
It sounds strange to me becuase it's cyclical. goes away for 3 seconds.. comes back for 3 seconds..
Kinda sounds like a little congo drum in my engine bay..
Hope it's belt related.
Here's a link to a movie I took this afternoon
Listen close its starts around 6 seconds in.
Thanks in advance for all of your suggestions.
Jim
Remove the serpentine belt and carefully inspect all the pulleys/tensioner and idler pulley. Pay close attention to the water pump for axial movement.
Swapping the water pump is not too bad, while you are there you might also want to clean out debris from the radiator intake and also check coolant tank for cracks as well. Good luck.
Awesome diagnosis! :notworthy:
