1. Saturday: Each time I start to accelerant over ~4000rmps I lose all acceleration. Check errors and get P1120 and P1121. Clear errors… as soon as I go over ~4000 rpms I can’t accelerant. Like I hit a rev-limiter.
2. Sunday: Switch out O2 sensors after cats running great.
3. I lost all Throttle response today. Restart and unable to accelerate after ~4000 rpms. Error code P1122 and P1120/P1121. I am thinking it’s the Throttle Valve Assembly 997-605-115-01-M14.
2002 Carrera C2 CAB.
Edited by Chris996
P1120 Throttle Valve – Signal Implausible
P1121
Throttle position sensor 1 - signal implausible
Throttle position sensor 1 - below limit
Throttle position sensor 1 - above limit
P1122
431 Throttle position sensor 2 - signal implausible
431 Throttle position sensor 2 - below limit
431 Throttle position sensor 2 - above limit
Possible fault cause
- Open circuit or short circuit in the wiring
- Throttle position sensor faulty
- DME control module faulty
Make sure the throttle valve connectors are secure and clean. Check for cuts or other damage.
Reset the codes and see if they come back.
