I have ordered this part (999 650 150 40) it is the blue connector that plugs into the headlight unit, it is clipped to the headlight undertray, does thid part include the short harness that plugs to a body mounted connector inside the trunk ? If it is just the blue plastic plug as I suspect from the price how is the old connector remoded and the new one installed on the short harness ?
I think you will need a pin removal tool to transfer the pins from the old connector to the new connector.
Sir Tools sells a pin tool kit or you might borrow one.
I am trying to remove the pins on the headlight connector using Sir Tools 12 pieces ST 9025, the tool tip that fits well is 'Flat Twin Blade 1.6 mm.
It is not removing the pins, tried warming the connector with a hair dryier, no success. Help needeed.
Thanks.
