M030 RoW Sport Suspension - 6 speed transmission
Then your front spring colors would be: Red/Yellow
and your rear spring colors would be: Silver/Red
M030 RoW Sport Suspension - Tiptronic transmission
and your rear spring colors would be: Silver/Yellow
Thats odd because my cars a manual & i have 3 colours on my springs. On the front i have on the top of the spring a white dot & at the bottom a blue & yellow dot. On the rear at the top theres a green dot & a red & yellow dot on the bottom ???
A = Identification of the running gear version (spring constant/spring length) by two different colored lines (for example, 1 x blue and 1 x white). Refer to the Parts Catalog for the allocation.
B = Identification of the coil spring tolerance group (load group) for determination of the compensation part (spring plate) thickness. 1 white line = 3.0 mm thick compensation part. 1 green line = 6.5 mm thick compensation part.
C = Color dot (color label) to differentiate the damper identifier.
White dot = Standard running gear RoW/USA
Green dot = Sport-type running gear RoW/USA
