Hi;
I have a problem with a 996 turbo.When the car is at operating temperature the abs and psm light goes on and the car is idling up and down,and sometimes stalling.The piwis tester gives the following faults:DME maf sensor and ABS torque transfer from engine disturbed some times.
I noticed in actual values (DME) that the outside temp is -137 degrees celsius.(-214 degrees F).
Is this related to the cars problem.
Thank you
The ABS and PSM MIL lights going on with no related codes is often a battery or charging issue; test the alternator's out put and have the battery load tested.
To test the MAF, unhook the MAF and drive the car. If the car runs good with a disconnected MAF, you need to replace the MAF.
