does anyone have any info on repairing the rear side window on a 2000 cab? mine has stopped going up. it's stuck down and makes a grinding noise. seems like that is what happens on the front ones when the regulator needs replacement. lots of info on replacing the front ones, but i can't find anything on the rear ones. figured i'd ask before tearing the car apart. it's the driver's side if that makes any difference - thanks, alan
ok - took things apart this afternoon based on the online guide. looks like this is a little beyond home repair (especially in my home) as the top mechanism is in the way. i can get to the glass but it appears like i will have to strip a lot of things out to get to the regulator. time to take it to the shop unless someone has a good idea.
