Hi! I have an intermittent noise (rattle) coming from the tiptronic during idle in position D or R, I lifted the car, engaged a gear, and noticed that the noise is coming from where the transmission is connected to the motor, it's a metal noise, not very loud and it's the same noise you could ear with a loose heat shield. I think that I always had this rattle but maybe now it's a little bit louder...
The question is, is that normal?
P.S. in N or P position I have no problems, the engine just run fine, i change the engine filter and oil every 5000 miles with a 5W40, I had my transmission serviced 30.000 miles ago.
thanks!!
Very difficult to diagnose noises via the net but a gearbox/engine rattle is not considered normal. Inspect all mounts and the torque convertor drive flex plate which can crack but honestly I have never seen it happen on a Porsche.
With my Durametric I also have code p0740 and an unknow 105... It seems that the rattle is louder when the car is warm.
In my opinion this noise could be coming from the tiptronic oil pump with normal wear, should I just wait for the worst? or can I do something to prevent any future problem? Anyway I'm considering to have IMS and RMS service...
  • 4 months later...
Update:
I had my torque converter changed with a new ZF original part, the IMS bearing update (just in case), new RMS. I had to pull down the motor and the tranny to do that and some other general maintenance
No more issue at all, it's like to have a new car! No more noise!
Total labor and parts costs: 4.000 € (5.200 $)
Edited by Doohan
