Yes --- very costly experience. Get the parts from Suncoast in Oregon --- You can buy new almost as cheap as used.
My top transmission locked up and burnt out the motor.
Chuck
Please let us know the outcome. I'm sure other cab owners would like to know the cost, process, etc.
  • 4 weeks later...
Any luck? My motor has struggled for a few weeks and is getting worse. I'm hoping its just a hydraulic leak as opposed to a burned out motor. Did yours just stop working or die gradually? Any help is appreciated.
I have a related problem. If I need to start a new topic let me know.
I followed the advice of this forum and added fluid to my top (it was below MIN). The pistons now work well, but I think either the sync is off or I screwed something up messing with it before I finally checked the fluid. So here's what going on:
1) I start by mechanically opening up the 'hook latch' on the front of the top (top is in the half way closed position).
2) I continue to close it....it closes and latches. And then there is the back lid motor running but does NOT close the back lid...it times out
3) I push the open switch, it unlatches, top goes all the way down, side flaps fold up......motor starts for lid closure, but doesn't move....times out
4) I open top, side flaps open, top starts closing.....goes a foot from the windshield and stops (as does the hydraulic motor).
5) I notice that the 'hook' has not opened to receive the slot.
6) I manually open the 'hook', hit the switch and it closes.
Is this a timing issue? Can the PST2 thing fix this.....or are there many more variables? Thing is, it was working fine and then one day it just 'stopped'....only 2 clicks...no motors
Thanks guys
