My 997 TT is about due for a transmission fluid change. There are plenty of threads discussing various trans fluid options but it seems that most people stick with the factory fluid which I believe is Delvac.
I seem to remember that you're not supposed use Delvac if you have a locking differential (which my car does). Is that right? And if so, which fluid should I use?
Cheers!
