When I go over a bump I hear squeaking noises from front n rear . Sometimes I hear them on flat surfaces as well . Less than a yr ago I had the front driver's side lower control arm replaced . My mechanic with out putting it on the lift stays it sounds like bushings as he test drove it . The rear sounds like it my be too low and hitting the rear exhaust pipes . Any idea ? If bushings need to be replaced can someone give me a listing of the bushings and part #s
Edited by clb0099
