Greetings! I am new to the forum. I recently purchased a 1999 996 C2 with Tiptronic trans, and I have a question.
The previous owner installed the red intake hose and BMC filter. They air box muffler is blocked off, but not removed.
The big question I have is: Where is the breather hose for the Tiptronic? I read that it must have it's own filter installed when this mod is done. But I cannot find the hose and/or breather.
It's possible that I'm looking in the wrong place. But I want to be sure it was done right. Can someone direct me to the correct location? Where does the hose go (or where SHOULD it go)?
Without a stock vehicle to compare to, I'm a little lost.
You can see in this uwfull picture mine is on the left of my intake and instead of putting a breather filter on it I have removed the helmholtz resonator and put it to the air box so its filtered (which is pretty much as OEM did it).
Edited by thirteeneast
Mine has the usual bypass hose to the air box muffler in that location. That hose is part of the stock air hose, and is removed. The air box muffler is then capped off as usual.
I do have the original hose that came with the car. I guess I'll need to examine that also.
I was told by someone else that not all 996s have this Tiptronic breather either. I do agree with you, that if it has one, hooking it to the air box would be the ideal way to go, to ensure that it has filtered air, etc.
Thanks for taking the time to post the pic!
Ah I see,
If your OEM intake does not have a little 10mm or so break out, Just behind the Helmholtz split and just infront of the Throttle then yours never had the breather.
I think it was only some tip's that had it for some reason?.
Well, I had it all apart to clean the throttle body today. The darn thing stalled out on me last night - out for dinner, came back and re-started car, temp around 100+ degrees, idle three blocks thru two stop signs, and it stalled. So I figured the throttle body might need cleaning.
Anyway, there is no Tip breather on mine. I checked the OEM hose that was in my spare parts box, and it only has the branch for the air box muffler. So, no other breather.
Thanks to everyone who replied, and thanks for the advice and direction. Mystery solved, I think. Now as long as it doesn't stall again....
