I've got an '01 GT3 Cup and the TPS is only showing 75% when the plate hits the stop. I believe i need at least 80% to get WOT signal to the ECU. Any adjustment procedure or fix that anyone is aware of?
Assuming it's not a T/B or pedal adjustment...
If it is cable op, could it be cable stretch (the 996 NA I own had this issue, I work with bicycles and have diagnosed the issue as cable stretch).
There are some hacks on the 996 NA to entertain (modify gas pedal underside). However on a cup car, if it is cable stretch, I would without a doubt replace the cables, and skip the hacks.
Edited by logray
