My transmission recently had two glitches when driving on Sebring at high speeds:
1. It went to "limp home mode" (third gear and no indications on the dashboard as to what gear it was in or what position the shifter was in). A red light came on the dash indicating the problem.
2. It stopped driving totally, as if I had moved the shifter to neutral.
In both cases things would reset if I stopped. For glitch number 1 I had to stop and re-start the engine for it to reset. For glitch number 2 to reset I had to stop, put it in Park, and go again.
I have a transmission leak. Could the above be a result of low transmission fluid level?
We did check error codes with an aftermarket code reader. It would connect with the engine ECU and give a TipTronic issue including that the transmission had slipped, and something about low voltage.
post-78792-0-10942100-1330999843_thumb.j
Hi there!
Sorry to hear about the troubles.
Do you have the trouble codes that the code reader provided?
Do you have a friend with a Porsche and a Durametric or PST2 or PIWIS that can connect to the transmission computer and read out the codes?
Hope it's something simple!
Yes, Low oil level could cause a problem, but more likely Transmission over temperature will be the cause. If lower than normal oil level then even less cooling.
you really do need a Durametric or PST2 to read any codes.
Transmission Slip.....understandable
Low voltage:?????? poor connector to from tCU to Gear Box, normally gets all the road dirt and moisture??
