Looking for quick advice on diagnosis and treatment.
Right front wheel won't turn at all. Is this a wheel bearing problem?
CV Joint?
Advice appreciated
No CV joint on the front of C2S (two-wheel drive).
Either a lock brake caliper (very unusual) or a wheel bearing. Closer inspection will tell.
Since it most likely is a wheel bearing - be sure to change both fronts at the same time.
This was very odd. Friday was a 6" snowfall. Car sat in garage until today, Monday and the right front wheel with slotted rotars rusted to a degree the wheel won't turn. Not a wheel bearing.
