Hello everyone. I have an 05 cayenne turbo and my check engine light came on with the code P0016. Has anyone figured this one out yet?
P0016 Position of inlet camshaft vis-a-vis crankshaft (in V8: bank 1) – above limit value/below limit value
Possible cause of fault
- Timing set incorrectly
- Chain extended
- Inlet camshaft loosened
- Rotor of inlet camshaft sensor (in V8: bank 1) in incorrect position
- Inlet camshaft sensor (in V8: bank 1) not installed correctly
do you guys have the timing marks or a blow up view for this motor so I can check it?
  • 7 months later...
