I need to find someone who can reprogram my DME from OBD2 to RoW in Miami. Looked at the registration tread but did not see a local post. Could anyone help or recommend a shop that can do this for me?
Depending on your model and year car there will be several options for coding. Best review those first.
You will need to get your IPAS codes from a friendly dealer - and protect them as they are the keys to your car. You will likely need to provide proof of ownership to obtain these. In most cases these should be given to you at no charge.
IPAS codes are required to do this level of programming.
