I put my Durametric (software version 5) on this vehicle. I haven't used it much so I'm not sure what to make of the codes it gave for the components below. I'd appreciate it if anyone can shed some light on them. Categories not reported showed no faults. I didn't look at the live data or whatever it's called because I didn't want to mess with anything. But the motor was running when I took the readings so that the battery wouldn't go dead.
Here's the output summary:
PSM
77B
Steering Angle Sensor
Kessy
955
Key1
A/C
353
Feedback from Blower Regulator
Front
Short to ground or positive
Electrical System
907
Load management operat. on vehicle
Electrical sys./DME control module
Present
If the battery voltage goes low for whatever reason you will get bogus codes such as these. Record all codes, clear them from all control units and monitor any that return.
Fault code 778 - Steering-angle Sensor
No signal from sensor.
Fault code 955 - Kessy
Battery in key is discharged.
Fault code 353 - Blower regulator not functioning
Feedback signal front blower regulator (manual, 2-zone and 4-zone air conditioning)
Low battery voltage or faulty controller.
Fault code 907 - Load management on vehicle electrical system
Low battery voltage or damaged wiring harness.
I agree with wvicary - replace the main battery, clear the codes and see if any come back.
Edited by Loren
  • 4 months later...
Hello Loren.
Does Fault code 907 has something to do with the head light elevation sensor, which is located at front left wheel?
I've 907 and 978 Bulb f. dipped beam headlight, l-m92 but lights does work. maybe the leveling not enpough?
Hello Loren.
Usually a battery issue. ALl kinds of strange things happen on Cayenne when the battery is weak or about to die.
