So next question is:
Has anyone done this change of sensor? if so how easy is it.
Looking at the service manual its shows to be fairly straight forward.
Here AutohausAZ has the OEM Bosch units for $119.25
http://www.autohausa...1417935@CAYENNE TURBO&year=2003&cid=19@Emission System&gid=5132@Oxygen Sensor
Fairly easy to get at from underneath, the aft O2 sensors are between the pre-cats & the main cats. Tie a string or piece of wire to the old sensor and pull it up from the top then fasten the new sensors connector to the bottom of the string so you can pull it up from on top. You may have to wiggle it and guide it a little bit to keep it from catching on things, sometimes helps to tape up the end of the connector so it is less likely to catch on things as you pull it through.
Sorry about that, didn't notice the location. If you can go to a Bosch retailer there you might be able to get it cheaper, the Bosch short # is 16498.
