I have an 06 S with 90k on it the service light is on. I have a durametric and can reset it - any significant maintainence that I should look at doing? It's running great - replaced coils and plugs at 80 and regularly do the oil/filters....Thanks
How's the serpentine drive belt looking?
Good question - not sure. I am guessing I should take a look - how long do they usually last?
The idea is to replace it before it fails and strands you.
Look for cracks, splits, or any other wear. At 90K it is likely worn.
If you do it by yourself (alone, in my case), use an extra long ratchet extension/breaker bar (3' of pipes). Made my job a lot easier!
