Is the brake pedal height adjustable? I just (finally) got around to installing my new Carnewal pedals and even though the gas pedal is about 3/8" higher and the brake/clutch about 1/4" lower the heel/toe angle is a bit too steep. Would like to lower the brake actuation about another 1/2"..
:drive:
Even though the part numbers are 997 numbers the parts diagram looks just like the 996. So the answer based on that would be no adjustment for the brake pedal. The clutch pedal should have a very small amount of adjustment by using the the threaded rod on the clutch master cylinder.
Thanks Loren. Wonder if there is an aftermarket adjustable assemby available? I suppose I will adapt to it if I have to..
