HI,
New here. Looking for recommendations on relatively inexpensive mods for a cayenne S 2006 titanium edition.
Any quick wins on this car? Air filter, exhaust, etc.
Can you fit a turbo on it aftermarket without busting the bank?
thanks
Jim
waste of monies, sell and buy a Turbo, so bottom line bear with it and leave your money in your pocket
Probably get a few horsepower with the Secondary Cat bypass but your not going to get anything with an air filter swap on a Cayenne S as the Turbo uses the same air filter setup and if it works for the Turbo (with a much higer airflow requirement) it's going to be more than enough for an 'S'. If you can get the Secondary Cat bypasses cheap enough or DIY then it will give you something but don't expect a big difference.
