My amplifier for 2003 Porsche Boxster with MOST (part 996.645.331.01) has gone bad so I am thinking of replacing it rather than redoing the entire system with new amp, headunit, etc. From what I can find online 996.645.331.XX (so 01, 02, 03) should all be the same part... does anyone know if I could swap my 996.645.331.01 with a 996.645.331.02 without problems?
You would need to find a shop with a Porsche PST2 or PIWIS tester to run the MOST config. As I said if you replace with the same parts you may not need to do that.
