Just replaced my water pump on 99 boxster. I notices all pulley except alternator and crankshaft are wobbling and making light grinding noise. I plan on replacing all pulley's but noticed the crankshaft pulley does not move. Is it suppose to move when turned by hand? Last, the pulley for the AC there is no part number for it and looks to be held in by one gold colored bolt. Does anyone have the part number for this? Thanks all
You can turn the crankshaft clockwise only and it requires a long 24mm wrench and some muscle. Play in the crankshaft pulley is from the clearance between the crankshaft and the main bearings and thrust shims. That play is measured in the thousandths of an inch. Any abnormalitites in crank play require engine tear down. In other words, I wouldn't worry about it.
I think I remember a thread or two about the AC pulley, if you spend some time with search.
