I had a dead battery and after I charged the battery back up, This light that normally just blinks is on constantly. I have no blown fuses. Any advice? I found no mention of what this might mean in the owner's manual.
thanks,
navin
the one that normally flashes when the alarm is set. right in the middle of the dashboard, on the top where the dash meets the glass, right in the middle of the car (side to side).
I believe Loren is correct. It is common for the alarm system to go into fault mode when the battery is changed out.
Edited by JFP in PA
Okay, I'll give it a try. by "double clicking the alarm" I'm going to guess that means pressing the key lock / unlock button twice.
thanks Loren and JFP.
I tried clicking my key remote button (the lock / unlock) button twice and then turning the key on in the ignition. It didn't fix the problem. Am I doing it wrong? Any other suggestions?
no, I don't but would be interested in purchasing one. I like stuff like that. Is there a "best place" to get one? I usually look for things on Amazon.com first, but is this something that is more specialized and would need to be purchased elsewhwere?
edit:
I found this:
http://www.amazon.com/Porsche-PIWIS-Engine-Diagnostics-Lights/dp/B006UJ0BMM/ref=sr_1_1?ie=UTF8&qid=1328279728&sr=8-1
$40 from amazon.com. is this reasonable or is there something better?
Edited by navin in KC
so is the one that I mentioned from Amazon what you are suggesting? or is there something better? (sorry to beat you up about this)
edit:
I found this:
http://www.amazon.co...28279728&sr=8-1
Be very careful about online PIWIS clones, while some are actually ripped off copies of early versions of the real software, many are early versions of the Durametric (or other non useful software). Porsche takes a really dim view of people that sell copies what they see as their intellectual property, and tend to come down very hard on them.
While a real PIWIS system lease is way outside the price range of all but the most dedicated individuals (well north of $15,000 for the first year), the Durametric software and cable is very good, reasonably priced at about $300, and affords you all future updates as well.
Just a thought..............
Edited by JFP in PA
