Purchased a used Tech Art for my car. Anyone help me find install instructions? I think its a the generation prior to "Vario" model. Lots of numbers on it, none that have lead me to find instructions
Appreciate any insight.
Thanks Wross, i dont think i have this system. can i send you a picutre. I dont have adjustment screws on top, i dont know if those stay connected after install but nonetheless, i dont have them. Is there a version prior to PSS9's that you know of?
The big problem with aftermarket parts is that almost NONE come with instructions. I would contact Tech Art. Then if that doesn"t work have a good tech install them for you.
The purpose of the suggestion to look at PSS9 was not that it is the same suspension, but that it does have installation instructions for suspension systems. I figured you could use those to help you with the install. If not, then follow phillip's advice.
