I have a 2002 996 C4. The compression springs that hold the parking brake shoe against the wheel hub came loose and disintegrated inside the rotor. Everything else looks good, but I need to replace the compression springs. Is there a difference between the one used on the Boxster and 911? The springs for the 911 are about $30 each while the Boxster springs are around $10 each.
911:
99635274100 compression spring. PRESSURE SPRING.
M008. 00-.2000 -2004- $26.19
Boxster:
98635274100 compression spring. PRESSURE SPRING.
$8.53
Yes, the normal Boxster uses smaller brakes than the Boxster S (and the Carrera).
The Boxster S and the Carrera use the same brakes.
So, use the Carrera or Boxster S springs.
