Hello all,
I'm experiencing a problem with the driver side window when closing the door.
The window operates normally when inside Up / Down / Auto Up / Auto Down functions.
The PROBLEM is when I open the door, the window goes down as expected but pulls up a second later as if the door was closed. When am inside or outside of the car and open the door, the window goes down enough to open it.
I need to pull the handle, both inside and outside, to lower the window and quickly close the door.
It seems the car thinks the door is closed when it's actually open.
Any advice would be very appreciated.
Thanks you in advance,
Hans
PS: The problem stated after I washed the car on a cold winter evening (-16 C) on my way back home.
This has already been discussed several times, the problem is the door lock micro switch.The lock thinks that the door is still closed even when they is open.Do a search for more info.
