What is a reasonable price for repair/replacement of a manifold gasket in a 1999 996 C4?
While getting the gasket replaced, what other work (if any) should be completed while the mechanic if replacing the gasket?
If you are talking about exhaust manifold...
This is a very easy job. If you know anyone that is even slightly mechanically inclined they can replace the gasket. Basically about 6 bolts and 3 nuts for the header and it pulls right off.
The only thing I would ask is, if you have a leak, is it because the bolts are not tight enough, is one borken or rusted, exhaust leak? Depending on what's wrong the price to repair could vary from cheap to put a helicoil in (likely case) and new bolts all the way to very expensive to replace the head (servere case).
The manifold bolts and the gasket themselves are only a few dollars each and probably set you back and hour or two of labor (unless it's severe).
if you are talking about intake manifold gaskets (orings actually), this is a much more involved job, probably looking at 2-4 hours in the shop because it is so tight and difficult to work in the engine bay without removing the engine. Again the orings and bolts are inexpensive.
