Successfully replaced the compression tank recently. However, engine got misfire @ blank 1 ( P0301 ).
When I replace the tank, 2 fuel lines were removed in order to gain access. ( Didn't drop the engine )
Would the misfire cause by air trap in the fuel line? Anyone has similar experience?
thanks,
Check for a cracked coil pack, or loose electrical connection. That would be cylinder 1.
You can always swap coil pack and/or spark plug one at a time to another cylinder to see which the fault follows.
Fault code went away and not happen again after cleared the code and sit for a few days.
Trying to " burp " the air out from the coolant tank now.
Attached the crack from the coolant tank as well.
post-46372-0-89130900-1328222299_thumb.j
