I am looking for a replacement transmission while I am tackling the rebuild on my 6-speed on the 2000 996.
There is plenty on offer on fleabay, but am concerned about compatibility between the years. I hear of short and long nose.
Any comments are appreciated.
JP
C2 uses 96/00 and 96/01
C4 uses 96/30
Thanks Loren.
In my case I am interested in form-factor. Does the 96/01 fit a 2000 996 C2 with original 3.4L engine?
JP
It should.
The mounting on the chassis changed in MY2001 but that is a (approx) $57 part.
As always: RTFM! I could have figured this out by just looking at the PET.
- The vertical carrier changed in 2001 (996 375 039 xx)
- The horizontal part changed in 2002 (996 375 031 xx)
Conclusion: Basically all MkI and MkII trannies on fleabay will work. Worst case scenario, I'll have to change our the carrier.
Thanks Loren! Your insight is appreciated as usual.
JP
