Hey guys, hope someone can help me...today driving back from michigan i ran into some problem with my 05 Cayenne Turbo. i drove about 100 miles and stopped to fill up some gas and after filling up, i turned the car back on and started to shake a little. Put it in drive and the car wouldn't go past 2k rpm and like 3-4 mph. and after a while the car would just shut off...any body know what the probable cause of this could be? I'm thinking its in limp mode but idk for what reason...when i filled up gas, i know it was premium, so idk what could have happened...
I assume the gas cap is on tight ?
If you left the engine running while filling with gas there is a chance that the gas check valve on the engine has gone and you got an airlock ( unusual)
You need to get a read on the errors, there will be codes, a Durametric or ODB reader
Edited by mudman2
I would test the EVAP control solenoid. The part has been updated to a newer design. Post the fault codes when you get them.
