I put on some new bilsteins and love them highly recomend them, but when i was testing for settings the driver front i had grease all over. The boot on the drive shaft slipped off and put grease everywhere. My question is what type of grease should I use to put back in when I reatach the boot? Thanks
soutahc4s
If it really is just the CV axle grease, here is a link . I think you actually may need to get the full kit that typically comes with grease, rubber boot, clamp (tool needed for proper tensioning), and the clip for the axle shaft. It is fairly involved since you have to loosen the suspension and pull the axle out to replace the boot.
