So for some off reason, my tach arrow ceases to glow on the dial and just disapears at night. No other lights are affected, does not seem to coencide with anythin (outside temp, driving style, alignment of planets, etc.). Sometimes it even goes for days without doing it, then either 1 or 100 minutes into driving, it's beatiful red glow dissapears. 2004 V6. Any ideas? Must I remove the dash?
How old is your battery? Have you had it tested recently?
A weak battery can cause all kinds of strange problems in Cayennes.
Have you had the cluster out for any reason?
If so, look for loose connectors.
Are you referring to the tach pointer needle going dim? If yes, I would think the bulb is failing or intermittent connection. I'm not sure if it's a conventional bulb you can replace or a surface mounted LED.
