I was looking for help/advice on replacing my stock rotors and wondering are the rotors on the 4S any different than an S?
I have checked several sites and no one seems to specifically list the 4S in the vehicle option for rotors.
J. B.
The brakes on a S model are bigger then on a non S model.
I would assume that a 2S and a 4S would be the same. You can
check the part numbers for the two models. If the pads are the same, then the
rotors are the same.
Not to hard to replace rotors with stock rotors.
Paul
