Any easy way to get a set of wires from the engine compartment to an area around the front console? I have 3 thermocouples to get to gauges mounted up front. Tnx
Edited by RayGT3
Underneath the ECU, there will be a rubber grommet that leads to the front passenger side engine compartment.
Remove the carpeted foam between the upper rear deck and where your rear seats would be.
Unbolt the ECU panel and you should see a body-colored rubber grommet below this area.
Get a 2 or 3 foot small metal rod or stiff wire and insert it from the inside. Go outside and look; it should come out by the front passenger side engine compartment near the passenger side rear wheel. Attach your wires and pull them through.
I ran my sport exhaust wires this way and then to the driver's side B-pillar, under the trim panel and to the fuse box area.
