So I went to do a rear wheel bearing R&R due to looseness in the wheel and intermittent noise under load. When I put the breaker on the axle nut, the thing just turned! It's supposed to be torqued to 340 ft-lbs!
I tightened it to spec and the looseness has disappeared, and I haven't been able to replicate the noise (it occurred mostly under engine braking).
Question is this: after a couple thousand miles of driving w/ intermittent mystery noise that looks to have been due to loose axle nut, is it likely that the bearing was damaged and that I ought to do the replacement anyway? I rented a tool to do it and would hate to have to jump through that hoop again, but the procedure does not look like much fun either.
If anything the service life of the brng has been shortened. I would still plan for replacement including the retaining nut. Did you check the torque value of the other wheel brng nut?
I didn't have a torque wrench that goes to 340 ft-lbs, so I had to do the "step on extension 2 ft away from pivot with my 165 lbs" method of torque. We couldn't break the other side loose even by stepping on the breaker, so assumed it was torqued properly.
I bought the car from a non-porsche dealer (got a great deal) that had replaced one wheel bearing after taking it in as a trade. I had someone else pick it up while I was out of town and he did not note which side had been done. My theory is that the loose nut was do to improper torquing after the previous R&R service - they probably just tightened it the same way you'd do on a normal car, which would be typically be less than 150 ft-lbs.
