Today I backed my car (MY03, 52K miles) out of the driveway and when turning the steering wheel noticed for the first time a significant amount of "wobble" as if the wheel is moving vertically up and down as I am turning it. Otherwise, the car ran fine, no noticible change in the quality of the drive. Any thoughts? Thanks in advance
On the old 911s they had a bearing on the steering shaft under the steering wheel that would break apart because it was made of plastic. I'm not sure if the newer cars have this problem or have never heard of a bearing in there, but it may be similar. Check for play in the steering wheel in all directions. If it does have play it might have some sort of bearing that breaks like the older cars.
