I have a 1998 996 tip.
Just had an engine rebuild and when the engine went back in the transmission control unit has blown I think when the transmission speed sender was unplugged/plugged back in).
The D and 4 lights are flashing showing its in Reduced Driving mode and it still drives finen auto mode. My mechanic is ordering in a replacement control unit, but says its fine to drive it in the mean time. My only concern is whether there is any risk of damage to the transmission given that I understand the control unit controls the Tiptronic coolant shutoff valve. Does this default to open (in which case I assume the transmission will be cooled fine) or is there a risk the transmission will be getting no coolant without the control unit operating?
Thanks for any help.
Brilliant. Thanks Richard. That's exactly what I was hoping for. That last bit from the manual re it being completely safe is missing from my 1998 manual, but that has put my mind at ease. Am a bit paranoid after my engine went!!
My 99 Tip went into that mode a couple of years ago and the dealer said it was likely due to not keeping the battery fully charged. They reset it for free.
The same thing happened a while later and I plugged in my OBD tool, cancelled the fault, went right out and got a battery tender and it hasn't happened again.
Hi scottiemac. Actually tried to find a fault with my durametric but it can't even find the tip control module, so I think the unit has actually gone unfortunately. Thanks for the tip though.
Find someone with a PST2 or PIWIS to check for faults.
Ok, I'm now a very happy man. After scottiemac's post I dug the durametric out again and tried with version 5 rather than 6 software this time. It found the tip unit and a "tip unit to dme" fault. I reset the fault and bingo, problem solved. All is good again. Thanks very much scottiemac!!!
Cool. I've heard on these forums that these cars are very sensitive to battery charge. If I'm not going to use mine for a while I plug in the battery tender and it seems to work great. My 5 series BMW is similar.
Good luck with it.
