My sunroof isnt closing flush when retracted. Can i adjust the way it sits with the 4 openings that are around the roof? If so, can someone tell me how to do it?
Thanks.
Try this first.
Teaching lifting/sliding roof drive
1. With the ignition switched on, press the lift button and move the lifting/sliding roof drive to the "raised"
limit position.
2. Press lift button again and keep depressed. After around 10 seconds, a complete cycle takes place from
the raised limit position to the positions "lower open close". Teaching of the characteristics has been
completed after this process.
Note: The lift button must not be released during the entire process. In the event of a restart, the
lifting/sliding roof must always be moved to the limit position first.
3. If the lifting/sliding roof drive should move back in Item 1, then the closing force limitation function has
responded (lifting/sliding force drive was taught). The open button must be re−taught in this case.
1 Press the open button until the sliding roof stops. Then release the button. Press the open button
again until the lifting/sliding roof drive stops again. Then release the button.
2 Press the open button again and keep depressed. The entire process takes place after approx. 10 seconds:
"close − lift − lower − open − close".
Edited by wross996TT
  • Upvote 2
  • 2 months later...
I can not open or close my sunroof in the usual way. If it is in the closed position, the open button is without function. I need to depress the closing or lifting button until the roof is lifted, then I can close the roof again with the open button. Only then I can open the roof either by pressing the open button (comfort function) or holding the open button. I have tried the above, but even then it works only once, and next time I have to repeat the procedure again.
Can anybody help??
Can anybody help??
Have you tried the re-training procedure listed above in the second post?
Yes, but after some minutes, it seems to be forgotten
Edited by thormann
