While changing my wheels and tires (to snows) I think I stripped the lug on the rt front. It seemed to be going in slightly rough, when I went to back it out didn't feel right but I was able to fully tighten the lug. Can this be fixed/retapped w/o replacing the rotor/hub?
Edited by C4S Surgeon
The hub might need to be replaced if there is serious damage to the threads, but if you inspect it by taking the rotor off and looking closely at the condition of the threads in the hub with a 10-power or better Lens ; you can tell how bad the damage is. If it is seizing up while you tighten up the lug it doesn't sound good. Be-sure to look at the lug bolt as well, you might want to try a new Lug bolt first.
D
Try cleaning the threads with a wire brush and try it again without the wheel on. If it goes in straight do not worry about it. You can use a little anti-seize to help lubricate it.
