The car was in a carport with a non water proof cover on. The two wheels on the open side of the carport had the center caps with the P. crest become opaque as if the transparent plastic has absorbed water and turned white. The wheels on the 'dry' side instead are OK. It appears as if water got below the plastic over the crest.
Replace? Wait and see if the moisture dries?
Did it get better?
