I havent seen this question covered yet, so Ill ask the stupid question. Is it normal that my transmission always starts in second gear? Very noob question, Im sure, but it seems odd that first gear never gets used...unless I put it in manual mode, that is. THX!
Yes it's normal behaviour with warm engine. The gearbox is only in first gear with cold engine, the warming up duration time of the O² sensors, or when manual manipulated.
In Auto mode, the tiptronic will almost always start out in 2nd gear (it will sometimes kick-down to 1st if you are on an incline, or hard on the throttle). If you are at a stop, and put it into Manual mode, then it will start in 1st gear.
I have always assumed that it starts in 2nd to help with fuel economy, smoother starts, and preventing wheel spin on slippery surfaces.
