If my packs are new as of 08 should I replace again.......? My idle kinda sucks. I know I have 50k mi on the current plugs.
Edited by ALEV8
Not unless they exhibit problems - at least I would not.
  • 4 months later...
I put the latest revision Porsches in along with plugs. Idle still sucks at least IMHO. Doesn't always start the first time either. Overall car accelerates better though. Been eyeing a Turbo S.....My Beru coilpacks are also latest revision and are pristine if anyone needs a set. My compulsion is your gain!
Edited by ALEV8
Latest coil packs are:
948.602.104.09 Bar ignition coils -- US MSRP $47.18 each
Are these the same for an '06 turbo s?
Check with your OPC as they might be covered in accordance with the TSB.
I have an 06 Turbo and just changed the plugs myself as part of normal 40K maint (car has 43K on it). Idle seems to now be rougher after putting in the new plugs. Could the issue really be the coilpacks instead. Where can I find the TSB?
