A few days ago I lowered the faceplate on my CDR220 and after that the radio will
not come on. No previous problem with radio or plate. Car is 2003 Boxster S with Bose woofr.
Fuse in main fusebox (D8..amp) is fine.
Unhooked battery, hoping to reset and then punch in radio code....no joy there either.
Pulled the radio to check for in line fuse but found none, all wire plugs in place.
I'm out of ideas her and could use some advice.
BTW... car also has the double beep intermittently upon lock/unlock. And is not currently
beeping.
Thanks Rick
