So, originally I had an issue where my "Individual Memory" option was missing from the PCM menu (likely because the control unit had been replaced previously), so I took the car in to have that activated. Apparently, during that process the "Radio Station" option was removed from the choices for the Central Display (below the digital speedo). Now, I only have "Empty" or "Estimated Range" or something like that.
My question is: Short of taking the car back to the dealer and having them jack with the computer some more, does anybody know of a way to re-activate this on my own?
My only choice would be to dis-connect the battery for about
3 to 5 minutes. This could reset everything. You will need to
re-teach your car how you drive.
Paul
My car does not have that option at all. It is a 05 C2S without SC. Do you know why I can not see radio option on my instrument cluster display ? Is there a way to add it to the menu ?
