thinking ahead about preventative maintenance and needed parts to keep on hand "just in case.....".
need part number for brake pedal switch for 2003 C4S, and DIY info if available.
I did several searches, and know I've seen this on the forum many times, but nothing came up.
Thanks, jl
There are two switches - one for brake lights and one for cruise control.
996-613-113-02 Switch -- US MSRP $18.45
996-613-114-01 Switch (cruise) -- US MSRP $18.45
It is a bayonet-type fitting. Turn the switch body 1/4 turn (counter-clockwise) and it should release from the bracket.
The adjustment procedure (if needed) is here:
http://www.renntech....post__p__191100
Thanks, Loren. I kept searching and did find many good threads on this issue. And I realized I had posted the wrong question. (Must be the meds....)
The switch I want to keep on hand is the clutch pedal switch that controls the starter..... Sorry for the mistake. jl
sorry to be such a pest...
is there a link to clutch switch replacement?
Lots on the brake pedal switch, but nothing I could find on the clutch pedal switch.
Happy New Year over there in Roseville. Sun shining today on the coast, but its cold and damp at night. jl
